Quick Excel help please!!
5 Jul 2007
NZ
This could be in the wrong forum but its a quick question on formatting in Excel (Excel 2007 if that makes a difference).
Basically I have a column with 500 rows of numbers in the format - 12345/1
I need them in the format 00012345/00001
How can I add in the extra 000's? Or make the cell automatically put 8 digits in front of the / and 5 after adding in the extra 0's automatically?
I'm useless at this sort of stuff and dont want to waste hours doing it all manually!
If you have no luck you can use the formula below to convert data, replacing A1 with the relevant cell reference.
="000"&LEFT(A1,5)&"/0000"&RIGHT(A1,1)
Cheers :) That formula sorted it. Must be something to do with Excel 2007 :confused:
EDIT: AWw now when I copy the fixed cells it copies the formulas rather than the values!! ARGH!!!
EDIT 2: Paste special F T W :D All done cheers!
