Quick excel macro question
16 Oct 2007
UK
I have this macro
Code:
Sub auto_open()
   ' Run the macro DidCellsChange any time a entry is made in a
   ' cell in Sheet1.
   ThisWorkbook.Worksheets("Sheet1").OnEntry = "DidCellsChange"
End Sub
Sub DidCellsChange()
  Dim KeyCells As String
   ' Define which cells should trigger the KeyCellsChanged macro.
   KeyCells = "B3:AD3, B5:AD5, B7:AD7, B9:AD9, B11:AD11, B13:AD13, B15:AD15, B17:AD17, B19:AD19, B21:AD21, B23:AD23, B25:AD25, B27:AD27, B29:AD29, B31:AD31, B33:AD33, B35:AD35, B37:AD37, B39:AD39, B41:AD41, B43:AD43, B45:AD45, B47:AD47"
   ' If the Activecell is one of the key cells, call the
   ' KeyCellsChanged macro.
   If Not Application.Intersect(ActiveCell, Range(KeyCells)) _
   Is Nothing Then KeyCellsChanged
End Sub
Sub KeyCellsChanged()
   Dim Cell As Object
   ' If the values in A11:C11 are greater than 50...
   For Each Cell In Range("B3:AD3")
   If Cell.Value = "H" Then
   ' Make the background color of the cell the 3rd color on the
   ' current palette.
   Cell.Interior.ColorIndex = 3
    Cell.Font.ColorIndex = 3
   Else
      If Cell.Value = "T" Then
   ' current palette.
   Cell.Interior.ColorIndex = 41
    Cell.Font.ColorIndex = 41
   Else
      If Cell.Value = "G" Then
   ' current palette.
    Cell.Font.ColorIndex = 1
   Else
         If Cell.Value = "" Then
   ' current palette.
   Cell.Interior.ColorIndex = xlNone
   Else
   ' Otherwise, set the background to none (default).
   End If
   End If
   End If
   End If
   Next Cell
End Sub
Which changes the cell color based on value
But if i clear the contents by pressing "delete" or similar, it remains the color of the previously entered value
I've tried changing the last IF argument to "", ClearContents and Empty, but no joy.
Any ideas?
Hi there,
You macro is only trigged when you open the workbook, have you had a look at coniditional formating within excel this will do what you are after and is always on :)
Hope this helps
Kevin.
You could try using the "Worksheet_change" method inside you VBA then :), I dont have excel at home so I am guessing :) this should do the trick :)
Private Sub Worksheet_Change(ByVal Target As Excel.Range)
If ActiveCell.Value = "5" Then
Code
end if
End Sub
You could use the worksheet change method, but if you tend to edit data in largish blocks (as opposed to occasionally altering a single value) it might slow it down, and you might be better putting it as an on_click on a button to do a block update.
