Quick Excel Question
16 Apr 2007
UK
Hey all,
Just a quick Excel question for you :)
I need to move the (x) axis down to the bottom (So the numbers on the axis are on the line of -30 on the (y) axis.
I hope this makes sense - I don't need the line to move, I just want the details on the (x) axis on the bottom line.
Any help would be appreciated :)
Thanks,
Marky
I'm on Excel 2007 here, but if I right click on the x-axis itself and select format axis, under the axis options, there's a "label distance from axis" option. Increase this until the labels are in the desired position. Iirc this option is present in 2003...but I'm not certain.
Even better, just noticed this:
Selected 'low' and the labels remain at the bottom all the time, no matter the size of the graph.
