Quick fan recommendation please...
12 May 2010
West Bromwich
Changed my case from Antec 902 to a Haf-X and in push pull antec tri cools on low, with H50, used to max out at 67 after half hour or so.
Now, with BitFenix Spectre fans, I'm up at 69-70 after 5 mins on the same cooler.
So can anybody recommend me some good 120mm fans, can't put tri cools back in rig because they're blue
Not too fussed about colour because I ordered som Lian Li red LED's for a bit of red bling. Just need a good performing couple of fans that aren't too loud. I like the look of the Gentle typhoons. The price says it all, only paid a fiver each for the Bitfenix.
Cheers, will pick them up the weekend.
