I received my computer from overclockers last week and overall I am very happy with it. It is a Titan envy duo with SLI EVGA GTX 980's. I just have 1 small question on the way the fans are setup. The case is a Corsair 750d and I am unsure if the way it is setup is optimal.
As you can see it has 2 fans on the front with a nice filter and the 2 fans on the top pulling air in through the water cooler but the top filter is not so good.
My question is should I change it so that the top 2 fans so that they exhaust through the radiator like this?
I really want to keep dust down so would much rather have all the air going through the fine filter in the front but obviously if I have more air going out than in i am going to have negative pressure and air/dust will be pulled through all of the open grills. so.... what would you do?
