Quick Farcry question
I've not actually tried with 1.4, but my guess (it is justa guess so dont hang me if you can!) would be no...
The way I got around it at 1.33 was to follow the full instructions for the 64bit patch, including patching to 1.33 (I think they may reference 1.31 ? cant remember anymore Im getting old)
Once you have the 64bit version running, copy the entire FC directory and store it in a safe place :P
Then uninstall all of the patches you applied (reverse order). From the DVD run uninstall/repair to return it to V1.0.
Apply 1.4 patch.
Launch 1.4 via standard shortcut, launch 64 bit via shortcut to equivalent file in 64 bit version...
