- 24 Sep 2005
- Middlesbrough
When you create a Virtual Pro, do you have to do the accomplishments for him to grow or can you just play through the seasons?
Thanks
Thanks
you can only unlock achievements on pro dificulty or higher, so your pro wont improve unless you play online or on that difficulty.
Is there any way of getting my VP into my existing Manager Mode? Only recently made a VP and I'm into the 2nd season in MM.
i ment semi pro![]()
