Quick G.Skill 2GB DDR2 NR PC2-6400 question.
18 Oct 2002
Newcastle, England
Is the default volts for the G.Skill 2GB DDR2 NR PC2-6400 1.9v or is it 1.8v? I think its 1.9v...
Package : 2048MB kit (2x1GB) dual channel pack
- CAS Latency : 5-5-5-5-15 (PC2-6400)
- Test Voltage : 1.9-2.0 V
- Speed : DDR2 800MHz (PC2-6400)
- Type : 240-pin DDR2
- Error Checking : Non-ECC
- Registered/Unbuffered : Unbuffered
- Quality Control : Comprehensive rigorously tested in pair at dual channel environment
- Warranty : Lifetime
Am I right?
It's 1.9, but it should run at 1.8 which is the 'standard' for DDR2 memory.
I couldn't get it running at all on a Gigabyte DQ6 regardless of the voltage
I had a problem with the G.Skill NR 6400& Gigabyte DS4 but since i have ironed that out they overclock well mate, i have mine upto 500mhz so far :D ..
How are people doing clocking these past 400FSB 1:1. I can do 5-5-5-15 up to 414FSB on 2.0v but havn't had much time to test, any more results? Don't mind dropping timings a bit, aiming for 428FSB approx. Going home this weekend too, not enough time :(
Set all your ram timings to auto at first past 400 to see how far the ram will go then tweak your ram settings accordingly..The timings in my other post are on default voltage settings..
