Ok - received my H80 during the week and will be putting into the case tomorrow but I'm hoping some of you others out there might be able to settle something for me.
1 - fan configuration - I was thinking of going for a push pull config with the blasting out the back of course (looking at maybe using a pair of the Scythe Gentle Typhoon fans to swap with the basic H80 ones - heard they're pretty good) - my case is a CM 690 II - is this configuration good for the airflow?
2 - I've heard some folks say they don't plug the H80 fans into the cooler on the cpu itself (I think that's what's normally done) - I was thinking of either placing them on a couple of motherboard jumpers or maybe just connect them upto a fan troller in one of my drive bays - good idea or not?
Thanks in advance for any advice!
