Permabanned
- 12 May 2005
- Worksop
What numbers are there for the sides?
I knw theres 1, 2, 3, are there any more?
fatiain said:There is only grade 1, shave it off you girl.
</gilly>
Zip said:I dont know what i get.
I just go in and ask, make it it a bit shoter and keep its style
My hair is now 2 or 3 inches long atm, when it reaches 4 inches its going to be cut back
Grow it long, you know its the right thing to do
I have a bad hairline for short hair![]()
</gilly>
According to Nismo there isn't a 7... which means they just shuffle around in the drawer for 5 mins and decide to give you an 8 because they're couldn't find the 7.trojan698 said:I get a 7 on top, always takes the hairdresser a half hour to find the damn thing tho![]()
vince said:3 back and sides, 7 top, tapered neck, sideburns to the top of the earlobe.
Borris said:4 top and sides.
The back should be left to flow freely, as nature intended.
