- 23 Apr 2024
- London
Hi all,
I'm just about to embark on my first hardline build. Can I just check which fittings are the 'easy to measure' type, where the tube hits the bottom of the fitting without being pressed in, so it's easier to measure the length of tube required? I hope I've made that make sense! I think the Thermaltake 16 mm Pacific C-PRO fittings are that type, but are there others?
Thanks in advance!
Thanks in advance!
