Quick Heatshrink question
7 Nov 2002
pantyhose factory
if I am using 2.5mm Braiding will 3.2mm HS with a 3:1 shrink ratio be a bit too snug to get over the braid ? I am going to take a punt that you can stretch the shrink a bit to get it on but you would end up with carpal tunnel syndrome and need the patience of a saint ?
Also are there any advantages to getting the adhesive lined HS over the regular ?
Does make it easier if its your first time though (less risk if braiding coming loose), just make-sure you do it right because as Clone says, its a PITA to get off!
