I am problmes with my web host. I am trying to use Macromedia Contribute to edit the site but it keeps timing out and crashing.
When I run a ping ping.exe www.mco.ie -t I recieve long pings several timeouts. The host says that there is nothing wrong with their webservers. I have tried pinging from my home broadband and the connection in work - I get the same problem.
I would appreciate if you could paste back your ping result and/or provide me with any reason why this might be happening.
Many thanks
Many thanks
Code:
C:\windows>ping.exe www.mco.ie -t
Pinging lithium.switchmedia.co.uk [217.205.162.200] with 32 bytes of data:
Reply from 217.205.162.200: bytes=32 time=155ms TTL=53
Reply from 217.205.162.200: bytes=32 time=207ms TTL=53
Reply from 217.205.162.200: bytes=32 time=194ms TTL=53
Request timed out.
Reply from 217.205.162.200: bytes=32 time=159ms TTL=53
Reply from 217.205.162.200: bytes=32 time=212ms TTL=53
Reply from 217.205.162.200: bytes=32 time=131ms TTL=53
Request timed out.
Request timed out.
Reply from 217.205.162.200: bytes=32 time=163ms TTL=53
Request timed out.
Request timed out.
