- 19 Jan 2021
Got a mlc Phoenix aio from ekwb. Want to change the god damn ugly black tubes and remove quick disconnect from it completely. Got some high pressure high temperature resistant silicon tubes. Ended up with a wrong dimension i think. I got 9mm inner diameter/13mm outer. Do i need bigger diameter tubes? Or can i go with 9/13. Will it cause waterflow restriction/ back pressure on the pump or increased pressure in the lines? or do i need the exact tube size? I think its 10/15mm?
Tnx in advance.
Tnx in advance.
