Quick help needed - hidden BIOS settings
14 Mar 2004
Brit in the USA
ASUS P7H55-M series board. Can't find how to change the RAM timings anywhere - I assume it's a hidden option. I've tried F1, which has worked on boards in the past, but no joy. My timmings have defaulted to 9-9-9 instead of 7-7-7 and I wanna change it, darn it :)
Thanks
Gah, I meant ctrl-F1......yeah, I usually buy Gigabyte myself. Thanks though.
Anybody else?
Looking at the Manual it should be AI Tweaker > DRAM Timing Control,
Page 2-11 in the manual.
I don't have AI Tweaker in there - I was hoping that's what would appear when I found the magic button :(
Starting to think you just can't do it on this mobo......which would be daft as how are you supposed to correct the RAM timings :confused:
That was from the manual for your motherboard!!, very strange :confused:
What are the menu options in the BIOS, As this does all the voltage tweaks, Speedstep ect.
It doesn't appear in my manual actually - I saw the AI Tweaker thing while looking around on-line, but it doesn't mention it in the manual.
I can't see any advanced features like voltage - either CPU or RAM. Just the very basic stuff. I can only select my RAM speed - nothing else. Fortunately, I'm not planning on overclocking......but I would like to be able to get the RAM timings right :(
EDIT TO ADD: This is the LX version of the board, which I knew wouldn't come with any overclocking options as standard. However, my RAM (g.skill ripjaws) is supposed to be 7-7-7 as standard - so I guess you're up the creek if it doesn't recognize the default settings.
I would say, as it is a budget motherboard the ram is going to be fixed at basic settings.
As for the ram being rated at 7-7-7, i think this means it can run at these speeds once you set it in bios.
