The code below was copied off a VBA learning site - it's a macro for copying and pasting particular rows into a new sheet. The macro selects any rows that contain a particular value in a particular column, and copies all of the selected rows into the next sheet.
I wanted to edit this so instead of searching for the EXACT cell value (Value="searchterm"), it would search for a particular string inside the cell. For example, at the moment, the code below only returns positive for cells containing only "searchterm" and not for a cell containing "blah blah searchterm blah".
Is there an easy way of doing this? I've been trawling vba forums for hours but can't find anything useful or anything I can understand. There's about 7000 entries in this excel database so a macro is pretty essential, and I can only work on computers using excel 2003. Would be extremely grateful for any help, thanks in advance .
Sub SearchForString()
Dim LSearchRow As Integer
Dim LCopyToRow As Integer
On Error GoTo Err_Execute
//Start search in row 4
LSearchRow = 4
//Start copying data to row 2 in Sheet2 (row counter variable)
LCopyToRow = 2
While Len(Range("A" & CStr(LSearchRow)).Value) > 0
//If value in column H = "searchterm", copy entire row to Sheet2
If Range("H" & CStr(LSearchRow)).Value = "searchterm" Then
//Select row in Sheet1 to copy
Rows(CStr(LSearchRow) & ":" & CStr(LSearchRow)).Select
Selection.Copy
//Paste row into Sheet2 in next row
Sheets("Sheet2").Select
Rows(CStr(LCopyToRow) & ":" & CStr(LCopyToRow)).Select
ActiveSheet.Paste
//Move counter to next row
LCopyToRow = LCopyToRow + 1
//Go back to Sheet1 to continue searching
Sheets("Sheet1").Select
End If
LSearchRow = LSearchRow + 1
Wend
//Position on cell A3
Application.CutCopyMode = False
Range("A3").Select
MsgBox "All matching data has been copied."
Exit Sub
Err_Execute:
MsgBox "An error occurred."
End Sub
