Quick help needed
Permabanned
29 Feb 2004
Right guys
I upped mu bios on my A8N-SLI to 1014 and now the thing wont boot with volts over 1.5???
How do i change back to 1013? a complete noobs guide needed :o
Do you have to do the update online?If not just rename the original BIN file to the new one you just flashed to then flash away.
Other than that you will need a floppy/usb stick(bootable of course) and a DOS flash program.
Never had an ASUS board so dont know what the flashing procedure is ie if its online or if you can do it through Winflash or whatever.
Steve
I used asus update to install the 1014 bios but now i want to go back to the older 1013? you saying that if i name that older bios to 1015 it will update?
