Quick help needed on new build.
Rite just built myself a new PC (for the first time) and i have some problems..
1, i looked at control panel, systems to see if it spots my 2gb of ram, and it see's it but next to it it says - physical address extension?? whats this mean?? did i put 1gb in the wrong slot??
2, i tryed to pop a creative FX card in to the new PC and i keeps poping up "Setup is unable to detect a supported product on your system. Please ensure that your product is properly installed before running this setup program" have i not installed a driver i should have done??? not pluged something in i should have done??
thanks for your any help.
spec -
Asus p5b deluxe
Intel Core 2 DUO E6600 LGA775 2.40GHz
GeIL 2GB (2x1GB) PC6400C4 800MHz DDR2 Dual Channel
Western Digital Caviar SE16 320GB SATA-II 16MB
GeForce 7600 GS 256MB
Antec Nine Hundred Ultimate Gaming case
OCZ GameXStream 700w Silent SLI Ready
spec -
Asus p5b deluxe
