quick help neeeded
12 Oct 2008
i was installin nvidia drivers, restarted PC and now i get a messege sayin MODE NOT SUPPORTED
apparently its at 640x480
what do i do as i cant see anything
the normal boot, then when it gets to the start up screen, the monitor says MODE NT SUPPORTED
also how can i run the PC in Safe Mode from the boot up?
can't you plug you're pc into the monitor your using now and change the resolution?
last resort maybe
the keystrokes to change resolution (in XP not sure about Vista)
pointer needs to be over desktop so drag to bottom right then up left a bit or something.
Right Click
Take your hand off the mouse because the rest is on the keyboard.
up <arrow>
<Enter>
hold <Shift> press <Tab>
right <Arrow> 10 times.
<Tab>
left <arrow> (decreases resolution, right arrow to increase)
<Enter>
