Quick help with fahmon
4 Sep 2005
London
Hey all
I just downloaded the latest version of fahmon, i've got the fahmon folder in my folding directory. I've loaded it up and downloaded the latest projects, and then i added my client into the list. Works fine.
However every time i open fahmon again, it doesn't remember my client, and it's just blank again. I have to re-add my folder to the list.
Any ideas? - Probably something really simple i've missed
Add the client(s) then click the X button to close FaHMon. Load it up again and your client list should be intact. Seems there is a bug that causes FaHMon not to write the info to the config file when it closes during a shutdown.
SiriusB
If you restart windows without closing FahMon down first then it won't save the settings - you only need to do it like that when you've made any changes though otherwise it's fine to just let windows kill it
If it's not due to a restart or anything then check the file/folder properties aren't set to read-only or something? :confused:
other than that I'm out of ideas :p
hope it's one of the above anyway :)
edit: getting old in my slow age :D
