quick help
17 Mar 2007
Plymouth
spec
abit ip35 pro
4*ocz platunim rev2 pc2 6400 ram
q6600@stock b3
tuniq tower
seagate hdds (sata)
ide dvd drive
sata dvd drive
hd2900Xt
FSP 700W psu
yesterday i took my pc apart to fit the tuniq tower cooler and to put a card reader in. after reassembling my pc, it does turn on and i can access the bios but i get constant error beeps.
i have rebuilt the pc. firstly with everything plugged in, then with
cpu, MB, Gpu and 1 stick of RAM.
also after fitting the tuniq, my Oc settting were lost
i have also tried a CMOS reset.
apart from unplugging the speaker any other suggestions for what i can do?
sorted it
it turned out i didnt plug the tuniq into the cpu fan header rather it was in an auxility header.
