- 22 Mar 2009
- Cornwall
can someone recommond a psu that has 4 PCI-E connectors please, this is the cheapest i have found, is it pretty good?
One sec man, for that budget you can get some epic PSUs.
Personally I would suggest this one if you are planning a i7/ dual GPU system with some headroom.
Edit: If you can get your hands on a PC Power & Cooling 750W silencer, get that.
As an aside, I though you just bought a 550W Antec PSU. Are you planning to add a lot of stuff to your system?
but my new one should be here tomorrow
