system specs
E7200
Abit AW9D-MAX (latest BIOS)
4x1GB OCZ DDR2 PC800 RAM
8800GT 256 MB
Problem
i took my Pc apart to fit a tuniq tower cooler and reasambled it, my problem is i cant get it to POST.
I know the CPU works in the MB, as it has been for the past 3 months. the only problem i get is the MB LED showing error code 8.7 which means a problem with the CPU voltage.
i have tried resetting the CMOS, short of puttign in a different CPU in the MB to set the CPU voltage, can you lot give me any ideas?
Thanks.
E7200
8800GT 256 MB
Problem
Thanks.
