Quick HFM Question....
23 Nov 2002
Near Bristol
Just a quick question regarding how HFM calulates PPD when you set it to Calculate PPD based on: All Frames. Under Edit>Preferences>Options
Does it use all the frames it has for that WU or all the frames it has for all projects in the log cache?
It uses all frame times for the current WU it is processing. If you pause a client for an extended period, when you resume it you'll see the PPD from that client drop like a brick.
Right ok, thanks for the clarification. Seems like the best mode to put it in anyways.
