Quick Hiper 580w and DFI NF4 Ultra-d question.
17 Feb 2004
HI, I am just building my new pc (my first build in years) and noticed the main power connection on the Hiper is smaller than the socket on the DFI by 4 pins, do you just plug the little 4 pin plug into the end so the 2 arrows on the plugs face each other ?
Thanks.
I think it was me being thick mate, you just plug the little square 4 pin dongle into the remaining holes, right ?
Yeah, some PSUs have a 20pin ATX power connector and a 4pin connector to add to it to make it ATX 2.0 compliant - or so I believe.
SiriusB
