Did my first ever overclock, on my i5 750 yesterday to 4ghz. I used 1.4v, a bclk of 200Mhz, and a multiplier of 20. Everything is running stable, and i get max temp of around 55 degrees on my H50.
I have a MSI GD65, and had been using the OC genie function, which clocked it at 3.4Ghz, and @ 1.4v anyway.
I was just wondering if the voltage was maybe a bit high, because I've seen some of the sigs of people with i5s and theyre running it at 1.3v or less in some cases. Would a high voltage have any effect on the lifespan of my cpu/mobo?
