Quick i7 spec check before pressing order
10 Aug 2006
Warrington
Want to reach 4ghz. Going to be using Scythe Gentle Typhoons on cooler but OCUK don't sell them :(
Everything best bang for buck and up to the task?
For motherboard, the Gigabyte GA-X58A-UD3R is a better choice in terms of bang for bucks, plus it has two USB3.0 ports and two SATA 6Gb/s:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-235-GI&groupid=701&catid=5&subcat=1692
It also can take i7 920/930 to 4GHz/4.3GHz
Sidenote: You gonna use existing HDD and PSU/Case right?
I saw one of the reviews that said it only had two USB ports, is this right, picture looks like it too, but the spec says diff. I'd need more than two and would go for it if it has these and is a stable good clocker
oh and ye existing parts will be used, although card to be upgraded with 5850, eventually two in crossfire and an intel SSD to be added later
the UD3 has ten USB2 ports, and two USB3 ports.
its in the latest custom pc mag, good review! 91%
While I cant comment on the UD3R I can tell you that the UD5 is utterly ROCK SOLID :D
Had mine comming up a year now and its been utterly flawless running at 4Ghz day in, day out.
Hands down best board I've ever owned.
4Ghz prime stable is not a given on either board, ive had 6 x58 boards and 4 I7 920s, the way each mobo/CPU combo clocks varys quite a bit, if you want 4Ghz i would be more worried about the power supplied by the mobo and also the cooling of NB/mosfets rather than how many sata 6gb and usb 3 ports it has.
What would you say is the cheapest most stable overclocking board you have had out of those 6 x58 boards then?
