I've just finally got around to trying it out, but I've noticed when IE8 is open task manager shows that it's running 2 instances of "iexplore.exe". Is this normal with IE8 ?
I've had a quick google and it suggests that if more then one instance is running the other might be malware, I just wanted to check to see if 2 are normal in IE8 before I go scanning for malware that might not even be there..
Appreciate any info.
