Quick IIS question..
ajf
ajf
30 Oct 2006
Worcestershire, UK
Is IIS a seperate product or is it included with Windows Server versions?
What version would it haev been with Windows Server 2000?
Thanks
Andrew
IIS is included with win2000. If it's not installed by default you add it via add/remove windows components
Google says Win server 2000 comes with version 5
Good luck
