- 11 Jul 2004
- Neptune
Not used it before, but heard it's the best.
If i have 6 laptops, and i get one exactly how i want all of them to be does Acronis allow me to create an image on a DVD, use it to boot each machine and then images it?
Is it that easy?!
Also, what should i know about changing the SID on each machine?
Thank you,
Is it that easy?!
Thank you,
) and the SID will be generated for each system -when you get say a new dell pc, they'll have sysprep'd then ghosted to your machine
