Quick info required.
Permabanned
22 Aug 2004
Hi all, looking to build a machine for a client using the onboard NV6100 graphics option as it is a pure non gameing PC, could someone tell me whether this has a DVI connector or a VGA/Analogue one as i cant seem to find out anywhere! the exact motherboard im looking at is the Asus A8N-VM S939.
Cheers chaps
i suspect its VGA as i havnt seen a mobo with an intergrated DVI port. but il have a quick look.
EDIT:
deadeyedic30 said:
Dual VGA Ouput:DVI-D & RGB From the Asus spec in OCUK
Owned :(
