Does anyone elses iPad2 not charge through usb? I can only charge it through the mains?
Do you know if I can still charge my iPad via my dock into my PC?
Thanks.
It does charge via USB, but more slowly and only when the screen is off. It will display 'Not Charging' otherwise.
Its the same with the dock.
No cases? I beg to differ![]()
Go on then. What do you suggest apart from that magnetic thing![]()
)Sena have a nice range of cases.
(Get your wallet out)
Whats your max price then?
It only charges with the screen off? Is the current draw too large for the system to run from usb? Basically needs a mains source of its own?
You can charge it via USB with the Asus USB booster tweak if you're on a PC
http://event.asus.com/mb/2010/ai_charger/
