Quick itunes question.
Permabanned
13 Jan 2005
I've accidentally downloaded a song from itunes onto my works PC, wheras actually i wanted it on my home PC (where i've can burn it to CD).
When i go home and log into itunes, will i be able to downloaded it from my 'home' install of itunes?
ANd if i cant do that, if i copy the mp4 file onto a usb stick and take it home,. will my 'home' itunes allow me to burn it to CD?
iTunes works as follows...
Using the store, you can authorise up to 5 PCs to play your tracks downloaded from the music store. Every track you have purchased from iTMS has your userid encrypted into it. When you go to play the track at home, it should just play straight away, as the PC is authorised to play music using your account.
