Quick Javascript problem. Any ideas?
12 Sep 2003
Newcastle, UK
Thanks in advance for any pointers, basically, I'm trying a simple Javascript program to retrieve data from a .XML file with DOM. The W3C Schools website gives me this example,
Code:
<html>
<head>
<script type="text/javascript" src="loadxmldoc.js">
</script>
</head>
<body>
<script type="text/javascript">
xmlDoc=loadXMLDoc("books.xml");
var x=xmlDoc.getElementsByTagName('price');
for (i=0;i<x.length;i++)
  document.write(x[i].childNodes[0].nodeValue)
  document.write("<br />")
</script>
</body>
</html>
So that should return the price, or if I change that value to say 'author' it returns the author. Simple!
So I saved the books.xml to my hard drive and copied that code into notepad and saved it as test.html. But when I run it locally, nothing happens?! :( I have Apache running as well.
Any ideas please?
Thanks!!!
EDIT: Here's the link where you can run the example,
http://www.w3schools.com/dom/dom_nodes_get.asp
http://www.w3schools.com/dom/tryit.asp?filename=try_dom_getelementsbytagname
Are you sure the path to your XML file is correct?
If the files are both in the same location/directory then the example should be fine - if the files arnt together then you will need to specify the path to your XML file.
Also do you have the file: <script type="text/javascript" src="loadxmldoc.js">?
Thanks for the reply, both the .xml file and the .html /.php file are in the same folder, such I try hard-coding a path in. I don't have a "loadxmldoc.js" file, but I thought that might just be something that is called in the background kind of thing.
? :confused:
Just shove this code into a new HTML doc and copy the books.xml file from the w3schools site into the same folder:-
Code:
<html>
<head>
function loadXMLDoc(dname)
var xmlDoc;
// code for IE
if (window.ActiveXObject)
xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
// code for Mozilla, Firefox, Opera, etc.
else if (document.implementation && document.implementation.createDocument)
xmlDoc=document.implementation.createDocument("","",null);
else
alert('Your browser cannot handle this script');
xmlDoc.async=false;
xmlDoc.load(dname);
return(xmlDoc);
function loadfile()
var x = xmlDoc.getElementsByTagName('price');
if (x.length == 0)
	document.write("No matching nodes found!");
else
</script>
</script>
</head>
<body onload="javascript:loadfile()">
</body>
</html>
Ahhh cheers for that, it seems to work now! :cool: yey!
I'm sure if I get stuck I'll ask again. :) Thanks again!!
