Quick jQuery selector question
20 Nov 2002
Barnsley
Hi guys,
I've got a little jQuery filter using Isotope http://isotope.metafizzy.co/ which updates depending on a jQuery selector as it's filter.
Basically what I have is multiple option sets all with a few options within each and I'm struggling to get it to filter how I want it.
Is it possible in jQuery to do something like the following in a selector:
Optionset
Option 1 OR
Option 2 OR
Option 3
AND
Optionset
Option 1 OR
Option 2
AND
Optionset
Option 1 OR
Option 2
...and so on and so forth. I'm not sure I'm explaining myself too well :p
This combo filter method is kind of what I want, but only 1 item is allowed to be selected per optionset http://isotope.metafizzy.co/demos/combination-filters.html
Let me know if you need further explanation and thanks in advance for any help :)
I think you're going to have to be a little more clear because unless I'm misunderstanding something, the combo filter is doing exactly what you're asking in your example.
Allowing you to choose one option from each of the sets.
I know, I said it was kind of doing what I wanted - but yeah I'm probably not clear enough sorry.
I'd like to be able to select any number of options from each optionset, but the logic applied for the filter should be as per my example.
Does that make more sense?
A little update to this, I've made an example so far using the combo filter thing here: http://codepen.io/anon/pen/zbiad
Basically what I want is to be able to click ANY number of options per optionset. So for instance if I click Black, Circle, then Small AND Medium clicked - the filter would display all black circles that are small OR medium. Also if something is selected, it can be unselected by clicking it again.
Cheers again for any help or pointers. I've a feeling I might be making a glaring error in my JavaScript on this bank holiday :p
Sorry in a bit of a rush but I think this is what you're looking for? Or there abouts :)
Code:
$.fn.extend({
    hasAllClasses: function (selectors)
        var self = this;
        for (i in selectors)
            if (!$(self).hasClass(selectors[i]))
                return false;
        return true;
jQuery(document).ready(function($)
    var $container = $('.items')
    var $debug = $('.filter-output');
    $('ul.filter a').click(function(event)
        var $this = $(this);
        var $optionSet = $this.parents('.option-set');
        $optionSet.find('.selected').removeClass('selected');
        $this.addClass('selected');
        event.preventDefault();
        applyFilters();
        return false;
    var getFilters = function()
        return $('ul.filter a.selected').map(function()
            return $(this).attr('data-filter-value');
        }).get();
    var applyFilters = function()
        applyFilter = getFilters();
        $debug.text(applyFilter.join(', '));
        $container.find('div').each(function()
            console.log(applyFilter);
            $this.css('display', $this.hasAllClasses(applyFilter) ? '' : 'none');
I think I need some kind of function to iterate through all possible options updating the selector variable to something like:
.black.square, .blue.square
That would be if black and blue were selected in the first optionset and just square in the second optionset.
My JS is a limited so any pointers appreciated.
Hey Deceptor,
I very much appreciate you having a bash at this, but just posted the JS into a fork of my code and it doesn't seem do do anything?
http://codepen.io/anon/pen/qivjl
Sorry I forgot the mention you need to change the attributes for the class values, remove the "." in the HTML so the HTML would be:
Code:
<p class="filter-output">&nbsp;</p>
<ul class="filter option-set" data-filter-group="colours">
  <li><a href="#" data-filter-value="black">Black</a></li>
  <li><a href="#" data-filter-value="blue">Blue</a></li>
  <li><a href="#" data-filter-value="red">Red</a></li>
</ul>
<ul class="filter option-set" data-filter-group="shape">
  <li><a href="#" data-filter-value="square">Square</a></li>
  <li><a href="#" data-filter-value="circle">Circle</a></li>
</ul>
<ul class="filter option-set" data-filter-group="size">
  <li><a href="#" data-filter-value="small">Small</a></li>
  <li><a href="#" data-filter-value="medium">Medium</a></li>
  <li><a href="#" data-filter-value="large">Large</a></li>
</ul>
<div class="items">
  <div class="item black circle small"></div>
  <div class="item blue circle medium"></div>
  <div class="item red square large"></div>
  <div class="item blue circle large"></div>
  <div class="item black square small"></div>
  <div class="item red circle medium"></div>
  <div class="item black square medium"></div>
  <div class="item blue square small"></div>
</div>
