Hi all, just a very quick question to do with kettle plugs. I am looking to buy a longer one to route around the back of some of my furniture, but I didn't know if there was specific ones to look out for, or are all UK Kettle plugs the same spec? I have a 1300w EVGA Supernova G2 so I just wanna make sure there isnt some spec changes with certain plugs that i'm not aware of and I cause some damage since it is power related
Thank you!
Thank you!
