Quick Lian-li pc7 plus question
28 Sep 2004
westmidlands
Hi guys, just a quick question about the above case, will it be big enough to fit these components.
.Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard
.Intel Core 2 DUO E6700 "LGA775 Conroe" 2.67GHz
.Leadtek GeForce 7950 GX2 1024MB GDDR3 TV-Out/Dual DVI
.Creative Sound Blaster X-Fi Xtreme Music
.Western Digital Raptor 74GB WD740GD 10,000RPM SATA 8MB Cache
.Samsung SpinPoint T HD300LJ 300GB SATA-II 8MB Cache
.NEC ND4571 16x16 DVD±RW Dual Layer LabelFlash ReWriter
.Akasa AK FC-03 Fan Controller Pro
.Ultra X Connect 2 550 psu
.Swiftech H20-220 Apex Ultra Watercooling Kit
Going to fix the radiator externally, so will there be enough room for a pump and reservoir inside the case? also will it be possible to control the fans on the rad with the akasa controller pro?
Thanks in advance.
Regards N
