Quick Macrium Reflect question
26 Feb 2004
Hampshire, England.
Hi guys,
I've just noticed that a Macrium update has installed a 'boot' folder in my C: drive, do I need it?
Thanks.
Depends what version of Reflect you are running, the update would not do this, but the installer would...
Stelly
Only the free version. I went to make a backup on Sunday and as I opened the program, downloaded an update and now I have the folder :)
It's a tiny folder but I do like a tidy C: drive...
Its used for the rescue CD, it is where all the WAIK and rescue files are kept when creating the rescue CD and needs to exist to create the iso/CD.
Stelly
Stelly
But if I've already created a cd? Would I still need it - I don't think I even created the cd on the machine in question?
Just thought it was a bit weird that its only appeared after my recent updating. As long as its nothing untoward, I'll leave it ;)
Thanks.
Thanks.
Basically it downloads a few files into the directory and mounts the wim file in that directory as well for the exe injection
Nothing untoward :)
Stelly
