This should be simple with some basic algebra, but I can't work it out (maths never my strong point)
In order to double the perceived volume of an amplifier you need to multiply the power by 4 times.
If I reduce the power by 25%, how much have I reduced the perceived volume by (%)?
)but i will concede that my assumption of V=cP^2 shouldn't be the case as normally it takes significantly more power to increase the perceived volume and so my answer of increasing p by 1/3 nearly doubles volume is clearly wrong from a realistic point of view
