Quick memory advice
14 Apr 2009
Cheshire
Need to build out a Ryzen 5 machine. Looking at 5600x in a tomahawk b550.
What's a good choice of ram...ideally that in stock at ocuk? Meets 3600 cl16 etc.. no need to clock higher. Stock is fine.
Thanks in advance.
+1 from me , solid and works for 3600 - I got the RGB version as it was on sale back in Feb/Mar - the MOD software is a big buggy but can be used with the lights turned off
Firstly I agree with every one above.
I nearly bought some new ram and this is the stuff I was going to buy.
By the way are you all recommending this off the back of the Digital Foundry video?
