Quick memory compatibility question
25 Jul 2010
A house
Current spec:
Intel Core i5-3570K 3.40GHz @4.8ghz
Noctua NH-D14
Corsair Obsidian 650D
MSI Z77A-GD65
Samsung 128GB SSD 830
Corsair Professional Series AX750w
8gb Mushkin Redline Ridgebacks 1866mhz
Asus Xonar Essence ST
Gigabyte Windforce 3 7970 ghz edition
Would like to upgrade to 16gb of memory.
Looking at getting either 1 or 2 of 8gb (2x4gb) Corsair Vengence Red 8GB DDR3 2133 MHz CAS 11-11-11-27
Will the memory work with my current memory, cpu and motherboard?
Checking around the web apparently the 3570k can only really use up to 1600mhz memory, but mine seems to be working fine?
Thanks.
Thanks, does this mean that i can just buy 1 set of the Corsair ram and it'll work fine with my current ram? Just the speed will be slower?
If the Mushkin cant run at the speed the Corsair stuff can then you have to run the memory to what the worst RAM can achieve.
