Quick Monitor Question
16 Jun 2014
Hey all,
My pc is bottlednecked in two places the CPU and my monitor. The CPU I'm dealing with elsewhere but I want to understand more about my monitor.
It's a 75hz native 2560x1440 supports freesync. (AOC Q3279VWFD8)
So I'm running a Sapphire Radeon 6800 XT as I figured much more than that would be a waste as the monitor would bottle neck it.
So my question is maybe silly. I still run games in the native 2560x1440 resolution but I wonder if my gpu would have an easier time of it at 1080? I just can't find a straight answer about whether running the monitor below it's native resolution will reduce performance or not?
Hey all,
Running lower than native looks bad. If you're getting way above 75fps with vsync/freesync off, set higher graphics setting for that game and then enable freesync
