Looking to purchase the following and was just wondering, although I like the Asus board, it is SLi whereas if I am having an ATi card, I might as well go for a board with crossfire. However all the crossfire boards seem cheaper, does this mean I would be better to keep with the Asus? (Probably won't ever use another card, but it's easier to have the option!!!)
Also would someone recommend a sound card to go with this or other suggested board. Only really need 2.1 sound.
Thankyou all (Good fun this shopping lark when you can finally afford it)
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
£67.95 £67.95
MY-057-OC OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series EL-DDR CAS2 (OCZ4002048ELDCPE-K) (MY-057-OC)
£144.95 £144.95
HD-023-SA Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM (HD-023-SA)
£35.95 £35.95
HD-018-SA Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA)
£61.95 £61.95
CD-026-NE NEC ND4551 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Black) - OEM (CD-026-NE)
£27.95 £27.95
MB-118-AS Asus A8N32-SLi Deluxe nForce4 SLi X16 (Socket 939) PCI-Express Motherboard (MB-118-AS)
£119.95 £119.95
CP-150-AM AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - OEM (CP-150-AM)
£118.95 £118.95
CB-020-GE Akasa Rounded Ultra ATA133/100/66 IDE Cable (0.45m) - Metal Braided (CB-020-GE)
£4.95 £4.95
CB-053-GE Akasa Serial ATA 45cm Silver Data Cable (CB-053-GE)
£3.50 £7.00
GX-048-PC PowerColor ATI Radeon X1800 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-048-PC)
£234.95 £234.95
Subtotal £824.55
VAT £144.30
Total £968.85
£67.95 £67.95
£144.95 £144.95
£35.95 £35.95
£61.95 £61.95
£27.95 £27.95
£119.95 £119.95
£118.95 £118.95
£4.95 £4.95
£3.50 £7.00
£234.95 £234.95
Subtotal £824.55
VAT £144.30
Total £968.85
