Quick Motherboard case mounting question
21 Oct 2002
UK
Hi Folks,
I have finally found the time to put together my new rig. I am just about to mount the motherboard in the case but I can't find any risers and screws to do it. Do they ususally come with the motherboard or with the case? If it is with the case then I have probably lost them as I had a spare case in my celler which I am using for this build. Can you buy just the screws by themselves from some of the larger pc retailers? Or do I need to buy a new case just to get a set of screws?
Thanks
Matt
Note that not all standoffs are equal, some are taller than others.
