- 29 Aug 2010
- United Kingdom
Hi guys,
So basically on my network I have my Desktop, And my HTPC running all the time, My Laptop and iPad. I set up my HTPC Specifically so that I can watch films on the iPad/Laptop e.t.c, But when accessing more than one movie at a time the machine tends to struggle, Its currently an AMD Athlon II X3 running at stock speeds, 4GB of DDR3 G.Skill ram. and No graphics card.
I do have a 5870 1GB sitting about but usually don't bother using it as I assume it wont affect the streaming greatly as its more down to the network? Is that right, Or should I put the 5870 in? Or should I look for a new router perhaps? I have a fairly modern Net gear RangeMax router, and has perfectly good signal on all devices using it.
Where should I look first/Whats the problem?
Thanks guys
Thanks guys
