Quick Nubsters WC Question .......
20 May 2007
lo !
Just wondering is there a certain or better order for the kit a in loop ?
i.e
Res / Pump (combined) Out => Rad => CPU => NB => Res / Pump In
or
Res / Pump (combined) Out => CPU => NB => Rad => Res / Pump In
Does the above make any difference ? Will either work, are both crap?
Comments much appreciated
Cheers
TB
It doesn't really matter since you have a combined res & pump. Whichever way is the easiest to route/uses the least tubing.
I go res - pump - CPU - NB - rad - res
Cheers Guys
I "think" ill be going
But just need to see how it all fits in the case when the bits arrive :)
Cheers again
TB
