Quick Outfit Question (360)
19 Oct 2002
Scotland
Just managed to get this cheap, **** come in a few days but i know the demo suffers from the whole 50hz problem. Does the full game suffer from this as well? :/
yeh i got this game, most underated game for 360! multiplayer and Co-op is great! i use VGA and it wanted me to change the Pal-50. so i had to get a tv all the way into my room (big messy room isnt easy!) attach the component cables and go into setup...after that change though went back to VGA and it works smoothly! :cool:
hope this helps
look foward to seeing you online?
Gamertag: VindiKatoR
Can you clear that up a bit, still leaves me confused how to do it. I'm using component at the moment?
Theres a switch on the plug xbox end to set the cable to HD or SD.
Turn xbox off.
Set switch to SD
Turn Xbox on.
Go into settings and change display to 60hz.
Turn xbox off.
Set switch on plug to HD.
Turn Xbox on.
Play game and say "Thanks VIRII you're a very nice chap".
