- 17 Aug 2008
hi everybody!
lol ermm.. now then, quick question. I found the beginners guide to overclocking and thought id give it a go, now i went to the bios and had a look about, started adjusting the clock speed it was at 266mhz by default, and it said the maximum was 350mhz but i adjusted it by 5 to 271mhz and it worked! only went up a tiny bit though, so i tried 276mhz and it workied. so i rebooted and tried 281mhz and it wouldnt boot up!! is that because i need to up the voltage? thanks. oh ive got a Asus P5VD2-X mb, and Intel Core 2 Duo E6600 and some crappy Kingston 2GB 2x1gb DDR2 667MHz mems in there too!
and after having a search, i feel i should also put that the pc is standard standard fans and stuff, and the case is a Aspire X-Cruiser Black ATX Windowed Gaming Case. its got it own fans tho! lol..
