Quick Parallels Q.
11 Jul 2004
Neptune
Am i right in thinking that if i was to have OSX and WinXP running on a Mac that XP works EXACTLY like it would on a standard laptop/PC? I basically need to know that if i have a Mac on an Win2k3 server that i can switch to XP, load outlook, check emails, sync my PDA etc etc...exactly as i would if i was using XP on it's own.
i understand that apps using non-universal binaries may suffer from being a little slower than 'normal' but other than that it'll work in the same way, yes?
Same goes with adding hardware to WinXP..autodecting etc?
Thanks
Correct :)
Everything is "passed thru" so all usb devices etc, networking etc etc.
XP doesn't even "know" it's a virtual machine.
Instead of me starting a new thread,
When Parallels is running Windows XP, is it running it "natively"?
Another question, what happens when you plug in something like a USB Flash Drive, how does it work out if it should go to the Host or Guest OS? I am guessing it is shared somehow as a USB mouse may be needed by both.
You don't pass things like mice and keyboards through, parallels sorts all that out automatically with it's mouse and keyboard drivers. For other devices you have a menu where you can pick which things to 'connect' to the host from a list of things plugged into the Mac.
Hope that makes sense :)
Not quite perfect
There is no 3D video acceleration with this emulation although I think they are working on it.Gaming is therefore not as good as on a proper Mac. :(
Lol, gaming via a virtual machine is just silly :) There's always BootCamp or possibly CrossOver if that's what floats your boat.
