quick PC7+ question
29 Oct 2002
Kent
How many and what size fans does the unit contain - slight conflicting evidence of whether its 1 or 2 120mm.
And what if any fans should I replace them with to make the case more efficient - Akasa ambers??
cheers, Am
From what i've heard, the latest PC-7+'s have 2x 120mm fans, but they are packaged in the old boxes (which say 1x 120mm + 1x 80mm), and so OcUK can't be sure about the layout without opening every box. Nearly everyone seems to be recieving the 2x120mm ones now though.
Akasa Ambers are ment to be a fair bit quieter than the fans that come with the case, more so at low voltages.
2x 120mm and 1x 80mm blowhole.
I would just run 2x 120mm Ambers personally.
(search for PC7+, this comes up daily with a longer response, usually on a Monday.)
wow fast, and excellents chaps thanks for the response
after months of thinking about what case ive gone with the cheapest :)
Am
Nothing about the PC7+ says its this cheap bar the price. :p
You will be pleasantly surprised when you recieve it.
